Author: Subject: EDIS being Wierd
prelude1980
posted on 13/9/07 at 11:35 AM Reply With Quote
EDIS being Wierd
I've got a 2 litre blactop zetec with MS2 V3 with EDIS
I've had the set-up going but not not running right, i've put a timing light on the leads to make sure i have sparks.
Cylinder 1,2 firing fine and fast.
Cylinder 3,4 firing intermittently and slower
When i swap the leads over the fault swap cyclinders.
I have replaced the coil and EDIS module with no improvement.
Can any one help
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
MkIndy7
posted on 13/9/07 at 11:44 AM Reply With Quote
Maybe worth looking at this thread:
Megasquirt Help
Discussed a few days ago... it looks like its probably a coil driver problem within Megasquirt, but yet to be resolved
prelude1980
posted on 13/9/07 at 11:55 AM Reply With Quote
does this still work the same as MS is only putting an output to the EDIS module that does the firing etc.
gets you.
MkIndy7
posted on 13/9/07 at 12:07 PM Reply With Quote
Erm... possibly not then.
The coil drivers for the MegasquirtNSpark are inside the megasquirt.
When using EDIS they are inside the EDIS/Motorcraft unit bit.
But the Megasquirt still controls the signal that tells each side of the coil WHEN to spark.
Aparently from the previous thread, they were sparking but as you've said not at the correct time, although theres was far enough out not to be able to start the car.
Might just have to wait for an update or U2U them .
[Edited on 13/9/07 by MkIndy7]
prelude1980
posted on 13/9/07 at 12:28 PM Reply With Quote
OK, 1 question then,
I'm using a timing light to monitor the sparking, when attached to no.1 the light flashes really fast which is normal but when still holding the triggeri open the clip around the lead the flashing goes slower. But when i do this on no.4 it's the complete opposite slow when clip closed and fast (normal) when open?
Does this sound right?
gets you.
Jenko
posted on 13/9/07 at 03:45 PM Reply With Quote
Reply
OK, so it's safe to say EDIS and coil pack are ok......
Other things to check
Plugs and leads
VR sensor wiring is correct way around
Coil connector
As the strobe uses an inductive pickup to trigger the light, I would not worry to much about the clamp.
posted on 13/9/07 at 03:57 PM Reply With Quote
One thing that can give weird results is a VR sensor bracket that can vibrate at certain revs.
Making sure that the sensor is mounted completely rigid will be a good move anyway.
prelude1980
posted on 13/9/07 at 05:45 PM Reply With Quote
i'll check the bracket but i'm sure it's rock solid
gets you.
