Author: Subject: Compression fittings on Fuel Line
Dave Bailey
posted on 22/9/07 at 04:57 PM Reply With Quote
Hi!,
I have used 6mm ID 8mm OD Kunifer for the fuel lines on my Zetec install and wanted to know if I can use 8mm olive compression fittings to convert the pipe to flexible hose? Not 100% sure what fitting I will use but how have people got cars through SVA and what is acceptable?
thanks
Dave B.
Aboardman
posted on 22/9/07 at 05:11 PM Reply With Quote
i just ran the rubber pipe over the copper pipe about 30mm and secured with jubliee clips.
sorry should add mine where the proper fuel clips not standard jubliee clips
[Edited on 22/9/07 by Aboardman]
Mal
posted on 22/9/07 at 05:22 PM Reply With Quote
Fuel Pipe Fittings
I used compression fittings on the 8mm copper fuel pipe for my car's SVA test without any problems.
Mal
posted on 22/9/07 at 05:47 PM Reply With Quote
You could also solder an olive or solder ringer coupler onto the end of the pipe. This gives a nice bead for rubber fuel hose to grip against and prevents fuel line clips and hose from sliding off.
2 things to remember, jubilee clips are a no-no for SVA (although some have passed with them) so use proper fuel line clips. Also any rubber hose should be marked on the outside as fuel hose to keep Mr SVA content.
HTH
Nick
MkIndy7
posted on 22/9/07 at 05:53 PM Reply With Quote
We've just got the correct round closing fuel pipe clips with the fuel hose pushed over the copper pipe. (although Jubilees's are fine the hose clips are better)
Compression fittings are also fine to use elsewhere if required... ours is running Fuel Injection now which is about 40 PSI where carbs are about 4 PSI and its all holding fine.
Dave Bailey
posted on 22/9/07 at 06:26 PM Reply With Quote
Thanks guys!
Dave B
Bigheppy
posted on 22/9/07 at 06:59 PM Reply With Quote
Fuel pipe
An easy way to put a flare on copper is to use the quater inch setting on a brake pipe flaring tool. Push fuel tube over it and secure with propper fuel pipe clip it'll never come off. Also rather than soldering bends its easy to form tight bends using an external bending spring available from a plumbers merchants.
posted on 22/9/07 at 07:15 PM Reply With Quote
Second flaring the pipes with a pipe flaring tool and Jubilee clips are NOT suitable for securing small rubber pipes
