Author: Subject: why does sky keep doing this?
blakep82
posted on 22/9/07 at 09:08 PM Reply With Quote
any one else had this problem?
got one sky plus box, and one normal box, multi room set up, both boxes on 1 satalite.
http://bebo.com/watch/4784370262
^ link for a video of what it does
this is the sky plus box. just stops and starts all the time. can't be the signal as the other box is fine (well, was, as it was until last night, now it says no satalite signal, but the sky plus isn't any worse
________________________
Paradoxia0
posted on 22/9/07 at 10:46 PM Reply With Quote
I have no answers I am afraid, but I sypathise with your annoyance...
My sky plus does the same. Virtually guarentee that everything that is recorded has a chunk where the audio is choppy and doesn't match the video... Very frustrating!
I also get where you hit plat, it runs for 5 seconds then locks up. Have to stop and re-start the playback to get it to work...
Mark
There is no replacement for displacement...
blakep82
posted on 22/9/07 at 10:57 PM Reply With Quote
exactly, stange thing is though, it records perfectly.
D Beddows
posted on 22/9/07 at 10:59 PM Reply With Quote
We've got a Virgin V+ box and they're b*llocks too - got 'upgraded' about 5 months ago when we moved house and I think we're on our 5th box now and this one is going tits up as we speak. Most Discovery channels either don't work or are extremely pixilated but they're fine on the original box from the old house we now have in the bedroom on the came cable connection...... The only good thing is Virgin just come round and give us a new box now no questions asked BUT you loose all your recorded stuff every time
blakep82
posted on 22/9/07 at 11:33 PM Reply With Quote
cant say who I work for but you will find the problem is at the back of the box with the f connector.
The center core is not big enough to give a good mechanical connection to the mounted female f con.
u2 u me and I will send you an adapter FTCOP
just went up there and had a look, the satalite dish input 2 cable was barely in its connector. the cable basically fell out when i turned the box around. shoved it back in (after unscrewing the connector itselfto have a look)
think the installer needs to come back and have another look at his wiring
seems alright now! thanks for your help
still need to have a look at the normal sky box, reckons its got no signal, but still knows what the schedule is though
jon_boy
posted on 23/9/07 at 11:03 AM Reply With Quote
With my sky, the picture and sound keep going slightly out of sync recently. Anyone else had this problem?
blakep82
posted on 23/9/07 at 11:29 AM Reply With Quote
mine has been doing that too. only noticed it since we got a 40" LCD, and didn't notice on the 28" CRT one. we just put it down to the new TV
AndyH
posted on 23/9/07 at 04:27 PM Reply With Quote
The connections in the plugs are a push fit, not a soldered connection anymore.
Thus, chocolate fireguard springs to mind.
blakep82
posted on 23/9/07 at 05:32 PM Reply With Quote
yeah, they had some electric tape to help, but with the heat they make the glue just melted
martyn_16v
posted on 23/9/07 at 07:17 PM Reply With Quote
Snap! Although I do think it is actually the new telly, if I turn the surround sound on whilst the telly sound is still turned up you can hear the time difference between the two
blakep82
posted on 23/9/07 at 07:21 PM Reply With Quote
sony telly?
