spud u like
posted on 24/9/07 at 04:49 PM |
anti diseselling valve
can anyone tell me what is a anti diseselling valve is
if so to wire this in to my kit car is it a switch live or perment live to make this work.
does it need to work to run the car .
many thanks
posted on 24/9/07 at 04:51 PM |
I think what you mean is an anti-diesling...
http://www.misterfixit.com/diesling.htm
EDIT: Speeling as gon dowwn ill...
[Edited on 24-9-07 by Hellfire]
posted on 24/9/07 at 05:51 PM |
Some MGB and mk 2 Escorts had them , solonoid operated valve that allowed air into the inlet manifold when the ignition was switched off. Think what
diesling means in what we would call running on.
posted on 24/9/07 at 07:22 PM |
On most MG and Fords it was tee connected into the brake servo vac hose. --- Simple solenoid valve supplied from an ignition switched +ve.
Suplying power via the ignition switch to it shut the valve, when the ignition was switched off it let a great gulp of air in to the inlet manifold
weaken the mixture and stopping the engine running on.
On some Vauxhall/Bedford and Japanese engines it was part of the carb and shut off fuel to the idle jet(s)
