posted on 8/10/07 at 12:48 PM |
throttle body question
question about zxr 600 throttle bodies although I suspect a lot of them are like this.
the bodies are circular at the air box end with round discs but at the manifold end the opening is an oval with a semi-circular cut out for the
injector - in otherwords the opening is not corcular.
now is the manfold the same shape?
I thnk the TB connect to manifold using circular tube so there will be a mismatch in the openings - or is the connector shaped to smooth out the
transistion from TB to inlet? (hope that makes sense).
posted on 9/10/07 at 08:53 AM |
yep - that is what I meant.
ok so to clairfy, the inner part of the rubbers match the cut outs in the bodies?
