Author: Subject: Fuel Tank design give me your opinion
Dave Bailey
posted on 16/10/07 at 03:32 PM Reply With Quote
O.k. So bought an all in one in tank pump breather and sender unit from an impreza but it is a bit tall. So have designed a tank so that I can use it. What do you think? How many problems am I going to have?
The tank has a sump for the pickup and I thought I would take the filler neck straight up to aid with filling seeing as the tank will be too high to get the filler out the back panel. Gives me about 7 gallons though!
Avoneer
posted on 16/10/07 at 04:11 PM Reply With Quote
Why not go wider and take each side right to the backward sloping chassis diagonal?
Apart from that, looks ok and a vertical filler is definately a good idea - something I wish I'd done.
Pat...
NeilP
posted on 16/10/07 at 04:13 PM Reply With Quote
Do you know if the sender will work on the tilt?...
Looks good apart from that - Are you going to do a little baffling around the bottom of the pump pickup?
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
Dave Bailey
posted on 16/10/07 at 04:17 PM Reply With Quote
I can't go the full width because the rear stays get in the way for getting it in and out. The full width would be 720mm and I can only use 650 of this....
Checked the sender and seems to work o.k. on the tilt....
thanks for the comments...keep em coming please...
posted on 16/10/07 at 05:56 PM Reply With Quote
With the pump mounted at that angle will the pick up at the higher side suck in air when fuel level drops effectively reducing tank volume?
pewe
posted on 16/10/07 at 06:19 PM Reply With Quote
Don't suppose you can shorten the pipes etc. under the flange plate or is that too easy?
Cheers, Pewe
Dave Bailey
posted on 16/10/07 at 06:25 PM Reply With Quote
I could shorten the bracket and straighten it up but at the moment the bracket is passivated so not to rust. If I cut the bracket then the weld to join it back together could go rusty.......
welderman
posted on 16/10/07 at 06:39 PM Reply With Quote
well it looks like mine a bit after i modified it a few weeks ago, but ive not got the tank breather thingy, otherwise looking ok to me.
[Edited on 16/10/07 by welderman]
[Edited on 16/10/07 by welderman]Image deleted by owner
Thank's, Joe
I don't stalk people
