RazMan
posted on 21/10/07 at 09:52 PM |
180 degree fuel pipe?
I need to route a fuel breather pipe in a tight 180 degree bend and can't find anything that doesn't kink easily. I have tried bending
some 6mm alloy tube around a 25mm pipe but it kinks every time.
Is there anything like a U bend with a 6-7mm o/d?
Raz
blakep82
posted on 21/10/07 at 10:00 PM |
this kind of thing?
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=281_430_286_301&products_id=1776
________________________
RazMan
posted on 21/10/07 at 10:04 PM |
Erm .... a bit ott at £14 each
I was thinking a bit more locost than that - basi8cally a bit of bent 6mm pipe
Raz
tegwin
posted on 21/10/07 at 10:05 PM |
Can you fill the 6mm ali tube with sand before you bend it?
blakep82
posted on 21/10/07 at 10:06 PM |
yeah, £14 is a bit much, but its there if you're stuck
or maybe this one!
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=281_430_286_301&products_id=1779
this ones £11.84
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=281_430_286_301&products_id=1775
[Edited on 21/10/07 by blakep82]
posted on 21/10/07 at 10:09 PM |
Put a piece of wire inside the pipe then bend it. Pull the wire out or melt the insulation off if it's too tight and pull it out a strand at a
time
RazMan
posted on 21/10/07 at 10:12 PM |
Now that's an excellent idea - and will cost nowt
Raz
omega 24 v6
posted on 21/10/07 at 10:14 PM |
Does it have to be 6mm?? I'm thinking 2 of 90 degree 8mm elbows for microbore heating pipes.
RazMan
posted on 21/10/07 at 10:17 PM |
I did actually think of that one and went into B&Q yesterday to have a poke around. The microbore elbows are 8mm i/d which makes them 10mm o/d so
a bit too chunky
Raz
omega 24 v6
posted on 21/10/07 at 10:24 PM |
OK another thought what about a bit of pipe from the condenser on the back of an old fridge or freezer??? Just be carefull of the refrigerant when
removing it
posted on 22/10/07 at 10:34 AM |
6mm for fuel breather -- way over the top even a bit of 3/16" brake pipe is big enough for a breather.
RazMan
posted on 22/10/07 at 11:35 AM |
removing it
.... I think swmbo might notice when her ice cream melts
Problem sorted now - packed the tube with salt, bent it around a former .... perfect!
bt - the pipe is only 3mm i/d
Raz
