Author: Subject: lockable diffs
posted on 23/12/07 at 11:19 PM Reply With Quote
lockable diffs
just wondering if any of you lot know of a 4x4 offroader that has lockable diffs but NOT in live axles? I need 3 lockable diffs to use with a dedion system.
Cheers!
zilspeed
posted on 23/12/07 at 11:54 PM Reply With Quote
Joel
Unless I'm very wrong, lockable diffs usually means actual proper off roaders and they usually have live axles.
Could be wrong of course.
NigeEss
posted on 24/12/07 at 12:07 AM Reply With Quote
What about the aftermarket locker people ?
Detroit and ARB for a start both make lockers for the modern soft roaders
which mostly run IRS and hence separate diffs.
Not a Locost option though
minitici
posted on 24/12/07 at 09:34 AM Reply With Quote
I seem to recall that early Audi Quattros had lockable diffs.
Think they used vacuum lines to control.
Like this one linky
[Edited on 24/12/07 by minitici]
Ricks-9r
posted on 24/12/07 at 10:39 AM Reply With Quote
the R33 gtr skyline has a electronically controlled locking rear LSD diff or prob better or cheaper option would be fitting traction control
posted on 24/12/07 at 04:20 PM Reply With Quote
cheers guys! I need proper locking diffs because its for an off roader, but i want to use a dedion so that i can have more clearance under the diff. I suppose i could just cut an axle super short and bolt on some driveshafts! I think more research is in order.
Im fairly sure i'll never build it but it would be nice to get donor parts lined up and modelled to fit.
