Ricks-9r
posted on 10/1/08 at 10:14 PM |
WNTED ,SIERRA 4X4 -COZY REAR OUTER CV JOINTS & DRIVE FLANGE/STUB AXLES
NEED THE REAR OUTER CV JOINT x 2 FROM SIERRA COSWORTH, 4X4 ,GRANADA & THE STUB AXLES THAT GO THROUGH THE HUBS & BOLTS PLEASE SO I CAN PUT MY
LSD IN ,IVE GOT THE INNERS & DRIVE SHAFTS ,W.H.Y. CHEERS
[Edited on 10/1/08 by Ricks-9r]
NeilP
posted on 10/1/08 at 10:24 PM |
Standard Sierra should fit - I've got a cossie diff with granny drive shafts and sierra hubs - pretty much all mix and match?...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
NS Dev
posted on 10/1/08 at 10:25 PM |
any rear disc sierra stuff will fit.
I have the bits if you can't find them closer.
Ricks-9r
posted on 12/1/08 at 11:49 AM |
re ,outer cvs /stub axles
U2U sent
![](/images//smilies/wink.gif)
tks
posted on 12/1/08 at 06:09 PM |
sierra will fit, my thought was that escort is bigger (wont fit-i know it isn't mentioned-)
cheers
Tks
Ricks-9r
posted on 14/1/08 at 07:39 PM |
Ive got the parts i needed now ,Cheers any way ![](/images//smilies/wink.gif)
