Author: Subject: fuel pump suction end ?
finlay
posted on 1/2/08 at 09:17 AM Reply With Quote
hello all
looking at the below fuel pump i cant tell which end is the suction, i am presuming its the larger of the 2 ie the 1/2" end with the green cap ?
many thanks
JAG
posted on 1/2/08 at 09:20 AM Reply With Quote
Look closely - there's usually an arrow on the casing showing the direction of flow.
Justin
RazMan
Yep, that's right
Raz
finlay
posted on 1/2/08 at 09:27 AM Reply With Quote
thats the first thing i did, was had a look but no arrows
posted on 1/2/08 at 09:34 AM Reply With Quote
The low pressure side of the pump will have the larger diameter port, in this case the one on the left of the pic.
Phil.J
posted on 1/2/08 at 01:32 PM Reply With Quote
Yes the power terminal end is the outlet.,
