rayward
posted on 11/2/08 at 04:49 PM |
trigger wheel for pinto??
what size trigger wheel have you used for a pinto pulley??
is fitting using the original bolt and then drilling an fitting a roll pin ok?.
cheers
Ray
[Edited on 11/2/08 by rayward]
snapper
posted on 11/2/08 at 05:44 PM |
The size of the wheel is unimportant as long as it a 36-1 for reference my one is almost a ring like a starter ring gear and about the same diameter
as the crank pully it is bolted to
[Edited on 11/2/08 by snapper]
I eat to survive
I drink to forget
snapper
posted on 11/2/08 at 05:49 PM |
finger trouble i will get it in the next post.
I eat to survive
I drink to forget
snapper
posted on 11/2/08 at 05:54 PM |
hopefully a photo will appear
I eat to survive
I drink to forget
snapper
posted on 11/2/08 at 05:57 PM |
The VR sensor could do with being higher up on my car as the bottom of it sticks through the engine bay floor a bit, it was alright in the Sierra it
came out of but a bit low for a 7.
Also if you can get the trigger wheel behind the crank pulley you do not need to move the VR sensor if you change the belt
I eat to survive
I drink to forget
