2b_pablo
posted on 20/2/08 at 03:28 PM |
max weight for blade engine?
posted this on the main forum but was told you lot tend to hang around in here.
in a nutshell whats the max weight of a car you would put a blade engine in?
Id guesstimate my RH is around 500kgs without the pinto.
cheers
if it aint broke... pull it off and upgrade it!
posted on 20/2/08 at 05:24 PM |
Our old one had an 893 and weighed in excess of 500kgs. Even two up it pulled like a good 'un... but personally I would not recommend going much
heavier as the clutch and g'box suffer under so much load.
ChrisGamlin
posted on 20/2/08 at 10:07 PM |
500kgs without the pinto installed = around 570kgs with a blade (and associated gubbins) installed making it over 150kgs heavier than a decent
lightweight BEC.
It will be OK but still around 50kgs heavier that what Id say is a good upper limit to target when installing a bike engine, IMHO, 2 up thats going to
weigh over 700kgs.
Chris
[Edited on 20/2/08 by ChrisGamlin]
