MKMike
posted on 22/2/08 at 10:38 AM |
Wideband Sensor With Megasquirt
Do I need a wideband controller or just a sensor with a megasquirt ecu.
Will this one work?
Link
paulf
posted on 22/2/08 at 11:32 AM |
Yes you do need a controller , that one would work but most people use the innovate LC1 which i think may be cheaper.
Paul.
ed_crouch
posted on 22/2/08 at 01:22 PM |
Yep, the MS system was designed to interface to a narrowband sensor, which basically just swings a voltage one way or the other to say rich or lean.
The wideband controller goes in the middle, between the MS and the lambda probe, and will output a precise voltage around the stoich voltage of a
narrowband sensor, allowing MS to discern HOW rich or HOW lean the engine is running.
the Wideband controller plugs into a wideband sensor, which has a nice linear (ish) characteristic. It also does something terribly technical with
something called a Nernst cell, and it runs a heater to keep the sensor up in its operational temperature regime.
Ed.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
MKMike
posted on 22/2/08 at 05:14 PM |
How about this one, will it work with Megasquirt?
Link
posted on 22/2/08 at 06:45 PM |
That has a 0-5v linear output so it should work fine with Megasquirt. It's a very good price too, if you can avoid customs...
http://www.plxdevices.com/products/sm/afr/
[Edited on 22/2/08 by MikeRJ]
posted on 24/2/08 at 11:28 PM |
Yes, the MS Lambda input is compatible with either a narrow band sensor, or the output from a wideband controller.
violentblue
posted on 25/2/08 at 01:09 AM |
I just built my megasquirt, and reflashed it for S&S-E, I'm also using the innovate LC1.
I like the fact that megasquirt is preprogrammed to use the LC1
a few pics of my other projects
