Author: Subject: Fuel Pump & Regulator
MKMike
posted on 27/2/08 at 12:14 PM Reply With Quote
What fuel pump and regulator do I need?
I'm rumming a 1.8 Zetec with GSXR 600 throttle bodies (injection) in an MK Indy.
matt_claydon
posted on 27/2/08 at 12:24 PM Reply With Quote
Any injection fuel pump will work, a common choice is a Bosch like this:
http://cgi.ebay.co.uk/AUDI-80-90-FUEL-INJECTION-PUMP-ALSO-A100-A200-NEW_W0QQitemZ300179585982
They are available with various different inlet and outlet fittings.
As for fuel pressure, GSXR 600 ran 3 bar as standard so you probably want to run the same so the flow rate is as specified (230 or 240cc/min ????)
[Edited on 27/2/08 by matt_claydon]
MKMike
posted on 27/2/08 at 09:08 PM Reply With Quote
Does anyone know where to get a 3bar pressure regulator?
Or what car they are standard on?
MKMike
posted on 28/2/08 at 11:07 AM Reply With Quote
I'm using Megasquirt, do I need one with a vacuum connection?
Any Ideas on a car that I could get one off?
MKMike
posted on 29/2/08 at 11:16 AM Reply With Quote
Do youknow what car the pressure regulatior came off or was it an adjustible one?
Most of the adjustible ones have a vacuum connection
