Author: Subject: GSXR600 injector info for MSII???...
Jenko
posted on 4/3/08 at 01:54 PM Reply With Quote
I know, it's been done before....But what have people used for the the GSXR600 injector setting in Megatune?.....And I'm not just talking flow rate (which I will start off at 230cc/min)....
So, what settings for:
Injector opening time
Battery voltage correction
PWM current limit
PWM time threshold
Injector PWM period
Also, if using a 36-1 toothed wheel - Under Trigger wheel settings, do you simply use the Tooth 1 angle (deg BTDC) of 90degrees? - Engine is a ford CVH?.
Thanks,
Paul.
[Edited on 4/3/08 by Jenko]
matt_claydon
posted on 4/3/08 at 04:54 PM Reply With Quote
You can forget the PWM stuff as they are high impedance injectors so do not need it. As for the other items I'd just leave them default, it works for most people.
Can't help with the trigger, it usually depends how you have oriented you wheel and sensor. If they are standard fit items then the info is probably on the MS forums somewhere or the MSnS-E site in the toothed wheel setup section.
