Lars
| posted on 19/3/08 at 06:55 PM |
Megasquirt placement
Just another quick question.
Where have people put their megasquirt?
Is the engine bay too hot?
I would prefer to mount it in the engine bay near the pedals, as I have space there.
And I don't really want to make a bracket to mount it else where.
Lars
mark chandler
| posted on 19/3/08 at 07:11 PM |
As long as you have quality wires anywhere you want really.
I found I needed a shielded cable for the RPM pickup off the coil pack.
If you look at an XJS jag, they have a MAP sensor ecu with the ECU in the boot, I suspect the delay is probally 1 mSec per meter on the vacumn tube,
so not noticable.
Regards Mark
[Edited on 19/3/08 by mark chandler]
matt_claydon
| posted on 19/3/08 at 08:11 PM |
In the MS manual it says it should be in the occupant area as the MS unit is not designed to cope with heat/moisture. I suspect heat may not really be
a problem (but stand to be corrected) however I would make very sure the unit cannot get wet.
darrens
| posted on 19/3/08 at 09:14 PM |
also bare in mind that if you plan on doing datalogging / changing setting whilist moving you will need to get a serial cable back to the interior.
I mounted mine under the scuttle (passanger side) so the serial cable can be removed completely when not in use.
Lars
| posted on 19/3/08 at 09:36 PM |
Must admit, I had forgotten about data logging, etc.
Seems I will have to make up some sort of bracket, and mount it under the scuttle.
What have other people done?
Lars
tim windmill
| posted on 20/3/08 at 08:44 AM |
under the scuttle gets my vote on pssenger side, easy access for data logging etc
martyn_16v
| posted on 24/3/08 at 05:20 PM |
Off the top of my head the only thing in the MS that isn't rated to the kind of temps you'd see in an engine bay is the MS1 processor
itself (the MS2 processor however is rated to automotive spec). But as has been mentioned, your number 1 problem is water, the standard case
isn't even vaguely splashproof, and neither is the DB37 connector supplied in most kits.
