violentblue
| posted on 29/3/08 at 10:15 PM |
Secondary Butterflies, fuel rail
Hi all,
working on my intake manifold and figured I'd better respace my ITB's so they'd fit better.
There a set of R1 ITBs with the secondary butterflies. not entirely sire what these are for but there seems to be a stepper motor or something that
controlls them.
I don't believe that megasquirt has provision to controll this, so shouls I just remove them or what?
I'd like to know the solution others have come up with for this.
also, extending the fuel rail, should I just cut it and use a section of pressure rated fuel line to bridge the gap?
a few pics of my other projects
vinny1275
| posted on 30/3/08 at 07:48 AM |
I'm using GSXR throttle bodies, they have the same arrangement. We've removed the secondary butterflies - I think these are like an
automatic choke - it's something you can live without. The latest version of megasquirt does have a controller for this iirc.
We bought a length of fuel rail and will drill it at appropriate spaces and then we'll make some brackets to hold it all in.
HTH
Vince
RazMan
| posted on 30/3/08 at 11:05 AM |
Aren't they something to do with improving torque at low revs? That's what my Duratec V6 had originally fitted - I removed them to make
mapping easier.
Raz
violentblue
| posted on 30/3/08 at 03:22 PM |
Thanks, that helps.
I think I'll remove the controller but keep the butterflies, but lock them at full open so I don't need to worry about sealing the holes
back up.
Jenko
| posted on 31/3/08 at 12:25 PM |
quote: Originally posted by violentblue
Thanks, that helps.
back up.
I wouldn't do that......get rid of them and fill the holes - It's not a hard job, and the air flow will not be compromised........
violentblue
| posted on 2/4/08 at 04:34 PM |
thought about converting the secondaries to locked ajustable system, so I can govern the max throttle for, just in case I let someone else drive.
spinning up some caps for the holes out of aluminium isn't difficult, but whats the fun in that?
[Edited on 2/4/08 by violentblue]
