Major Stare
| posted on 31/3/08 at 09:01 PM |
Sealing unions on fuel rail... with what?
I have tapped and threaded my billet fuel rail to accept the threaded unions.
But, how to i seal these?
Plumbing thread tape isnt ideal and will corrode with contact of fuel.
Could i use locktite thread lock?
Jon "FISH"
imp paul
| posted on 31/3/08 at 09:18 PM |
try copper washers to seal fittings
Major Stare
| posted on 31/3/08 at 09:20 PM |
tried but not convinced.
Want something to seal the threads?
Jon "FISH"
Confused but excited.
| posted on 31/3/08 at 09:27 PM |
PTFE tape will not corrode.
daviep
| posted on 31/3/08 at 10:14 PM |
What type of fitting have tapped the rail to accept?
Tapered threads (npt, bspt) seal on the threads using ptfe tape or thread paste such as swak or a loctite type pipe sealant.
Most other fittings seal on the faces using copper or dowty washers or o rings.
Alternatively there may be a conical metal to metal seal such as JIC or BSP.
Just a few examples, but basically every fitting is designed to achieve a reliable seal if made up correctly.
So again what type of fitting/connection are you using?
Davie
v8kid
| posted on 1/4/08 at 05:53 AM |
PTFE tape is the standard reccommendation. I use the thicher "one wrap" gas tape and wrap it untill I can't see he threads.
I presume you are using tapered threads? BSP or NPT. If not you need a fitting with a shoulder and use a copper washer - but your tapping has to be
perfectly ay 90 degrees or it will leak.
Major Stare
| posted on 1/4/08 at 06:37 AM |
Cheers guys.
The unions look like this....
and are tapped into a fuel rail very similar to this.....
Jon "FISH"
| posted on 1/4/08 at 08:37 AM |
Red Foliac jointing compound is fuel
and oil resistant.
| posted on 1/4/08 at 08:57 AM |
^^^ thos look like standard 6 or 8 mm hose tails - you can buy them with tapered thread - ofcourse no use if you have tapped to some other size.
Major Stare
| posted on 1/4/08 at 08:09 PM |
That Red Foliac looks just the stuff.
Jon "FISH"
Major Stare
| posted on 1/4/08 at 08:46 PM |
e-Bay does have its uses. This should do the job !!!
Jon "FISH"
violentblue
| posted on 2/4/08 at 04:36 PM |
and oil resistant.
yup pipe dope is what we call it around here. thats the stuf to use
a few pics of my other projects
Major Stare
| posted on 2/4/08 at 09:35 PM |
Would this also work?
Jon "FISH"
stevebubs
| posted on 2/4/08 at 11:28 PM |
If you're not planning on removing them, braze them on....
Major Stare
| posted on 3/4/08 at 06:19 AM |
Not planning on removing it and dont have access to braze them on.
Will the stuff i posted i link to work?
Jon "FISH"
