Guinness
| posted on 23/4/08 at 04:09 PM |
Custom Mapping
via the medium of "Etch a Sketch"
See info here: http://www.m0rksport.co.uk/shop/index.php?act=viewProd&productId=2
Mike
clairetoo
| posted on 23/4/08 at 04:12 PM |
Its cuz I is blond , innit
Claire xx
Will weld for food......
RazMan
| posted on 23/4/08 at 05:11 PM |
"Care must be taken on diesels, since during the mapping process the excessive vibration caused by the tractor like engines can cause the custom
mapping tool to loose it's detail.
If you want to revert to standard, all you need to do is connect the etch-a-sketch to the OBDII port & simply shake the unit."
Raz
