Author: Subject: throttle peddle movement
iiyama
posted on 8/5/08 at 10:05 PM Reply With Quote
I need to make the peddle travel longer as from idle to WOT is around 1" of peddle movment
Was thinking along the lines of introducing a bell crank at around a 2:1 ratio, maybe slightly less. Anyone got any other ideas?
cheers
If its broke, fix it. If it aint broke, take it apart and find out how it works!
twybrow
posted on 8/5/08 at 10:07 PM Reply With Quote
Floor mounted or high-mounted?
Can you not just move the cable further from the pivot point?
iiyama
posted on 8/5/08 at 10:10 PM Reply With Quote
high mounted.
Unfortunatly not. where it would ideally go is a mounting point for the peddle box. If I move it to the other side of this then it is very close to the rear M/C bellows and pushrod and I figure Mr. SVA might not like that very much.
Also dont I want to move it closer to the pivot point? Cant do that because of the aforementioned!
[Edited on 8/5/08 by iiyama]
twybrow
posted on 8/5/08 at 10:31 PM Reply With Quote
Sorry, stupid moment. yes, you need to move it closer to the pivot.
Got a pic, so we can see the problem? Where are you thinking of adding the bell crank?
zetec7
posted on 9/5/08 at 12:11 AM Reply With Quote
How about adding a bellcrank? You could easliy change the cable movement ratio that way...
http://www.freewebs.com/zetec7/
nz_climber
posted on 9/5/08 at 01:41 AM Reply With Quote
what about changing the size of the pulley/lever on the throttle body/carb to adjust your pedal to throttle movement?
http://aarons7.wordpress.com
adithorp
posted on 9/5/08 at 06:33 AM Reply With Quote
I'd put a bell crank in.
Whats WOT?
adrian
westf27
posted on 9/5/08 at 07:11 AM Reply With Quote
wide open throttle ? maybe
iiyama
posted on 9/5/08 at 07:59 AM Reply With Quote
Yes indeed, WOT is wide open throttle.
Ill take some pics and post em up in an hour or so.
Would be happy to change the lever/pulley on the throttle bodies as that would be a much simpler solution then adding a bellcrank into the line.
iiyama
posted on 9/5/08 at 08:54 AM Reply With Quote
OK, pics!
Movement strangly looks a lot more in the pics then in actually is!!!
This is where I was thinking of mounting a bellcrank ie where the throttle cable is supported.....
[Edited on 9/5/08 by iiyama]
iiyama
posted on 10/5/08 at 09:11 AM Reply With Quote
I post art and you all run away!!! Something I said? LOL
