Author: Subject: Wanted - Zetec on TBs maps from any management
garage19
posted on 19/5/08 at 08:16 AM Reply With Quote
Has any one got any map files or screen shots for maps from a 2ltr zetec on throttle bodies?
Please include a little info on who and how it was mapped.
Particularly interested in ignition maps.
Thanks,
Doug.
nre
posted on 19/5/08 at 10:11 AM Reply With Quote
My 1.8 Zetec on GSXR750 TBs mapped on road using wideband (ignition map is based on map attached in my next post!)
Both Emerald maps so download software from Emerald to see the maps.
Neil
[Edited on 19/5/08 by nre]
Sylva Mojo Zetec on GSXR750 throttle bodies...
www.mymojo.co.uk - Facebook feed
JPSC Forum - A dedicated forum for discussion on all things relating to Jeremy Phillips designed cars
Including the Star, Leader, Striker, Phoenix, Fury, Jester, Stylus, Mojo, Riot, J15 & Vectis
nre
posted on 19/5/08 at 10:13 AM Reply With Quote
A friend's 2.0 Zetec on GSXR600 TBs mapped at Emerald.
Neil
muzchap
posted on 19/5/08 at 10:30 AM Reply With Quote
I have a 2.0L mapped on Gixer 750 TB's - running 3bar fuel pressure.
Megasquirt map.
U2U me if interested.
M
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
garage19
posted on 19/5/08 at 11:16 AM Reply With Quote
Just looking at the maps in txt format its quite intersting that the ignition maps look quite different. There also seem to be some very high values in there.
The starting ign value is 6 deg on one and 24 deg on the other. Both not what i would have put for a cranking figure. Odd?
nre
posted on 19/5/08 at 02:55 PM Reply With Quote
Be warned that the emerald format means that the advance values in the file are double what they are in reality! So I'm not really running 80 degrees advance!
Best to get the software as mentioned before...
Neil
Jenko
posted on 19/5/08 at 07:34 PM Reply With Quote
The ignition maps will be of use, but the fuel maps wont.......You simply cant compare VE tables, as the numbers are dependent on a number of other different settings - Injector flow rates, required AFR....so if you are going to copy a VE MAP, ALL other inputs to MS must be the same........A wide band willl help you tune your own map :-)
Paul.
garage19
posted on 23/5/08 at 09:44 PM Reply With Quote
As i said, particularly interested in the ign maps. Just wanted to get a rough handle on the sort of ign advance people are running on zetec engines.
