Steve Lovelock
posted on 25/5/08 at 05:30 PM |
Running well at last - feedback appreciated
Well it has been about two years since I bought a soldering iron and a bag of electronic bits but I have finally driven my car properly. The time
frame should tell you everything you need to understand about my skills in this area. However, having got this far I would like some feedback on my
data logged files. Two reasons for this, 1) SVA on Tuesday. 2) I can only data log on a path that is about 100m long. Also a final question, does
megalog viewer alter timing as well as VE tables?
Thank you to everybody who has answer my stupidly daft questions during the last two years.
posted on 25/5/08 at 09:06 PM |
Glad you have got it sorted at last Steve . Couldn't help with your Megasquirt problems , might be worth taking the laptop with you on Tuesday?
MkIndy7
posted on 25/5/08 at 09:37 PM |
Unless i'm mistaken the above file is just the Megasquirt settings file and not a Log of the car running?.
Afaik Megalog can't alter the ignition timing as well as it has nothing to compare it to, there is no device for measuring knock or the timing
like there is the Lambda for the VE.
