Author: Subject: Head skim
triumphdave
posted on 7/6/08 at 05:10 PM Reply With Quote
Head skim
Can anyone tell me of the implications of having a head that has been skimmed approx 1/2mm below the recommended limit.The head is fitted and the engine is running well,so I know the valves are not touching the pistons,It starts O.K too so I dont think the compression is too excessive,just curious really as to any long term damage.The head was supposidly done by a reputably good head specialised,where it was ported polished and skimmed.Is it possible it was done deliberate for power reasons?.
dubstar_04
posted on 7/6/08 at 05:42 PM Reply With Quote
My biggest concern would be the cam timing if it has had 2mm taken off, unless your using a vernier pulley.
If you have compression tested it and it runs well then I wouldn't worry.
[Edited on 7/6/08 by dubstar_04]
