omega0684
| posted on 20/6/08 at 03:38 PM |
config error in megatune
i know have a config error box that is red at the bottom left corner of the screen when i open up megatune, what does this mean?
omega 24 v6
| posted on 20/6/08 at 05:05 PM |
Ok going from you other post it's most likely you have 2 sets of spark setups conflicting with each other. this usually results in the fuel
pump/relay pulsing off and on. Before you turn on the ignition Go to communications on the top tool bar of megatune and select mini terminal
(you'll need the laptop and a serial cable for comms.) open the mini terminal and then turn on the ign. It should tell you automatically what
the conflict is ( you may need to try this a couple of times.
omega0684
| posted on 20/6/08 at 05:21 PM |
it says
"you connot have more than one spark mode defined"
but what now, what spark mode is it on about? where do i turn one of them off, if you see what i mean?
omega 24 v6
| posted on 20/6/08 at 05:26 PM |
What spark setup are you ACTUALLY using on the car??
omega0684
| posted on 20/6/08 at 05:38 PM |
edis wasted spark
omega 24 v6
| posted on 20/6/08 at 06:28 PM |
Mmm ok so trigger wheel?? In megatune go to "basic settings" "codebase outputs/functions" and turn on "edis" every
thing else should be turned off . You must have more than one of the top table settings turned on at the moment to have a conflict.I don't know
if you need "edis mutispark"on or not I'm afraid as i'm not using edis. You'll need to read up a bit about it yourself
anyways.
