sprouts-car
posted on 30/7/08 at 01:42 PM |
Wanted: Mushroom inserts and brakes
Does anyone have, or know a place that has mushroom inserts for sierra uprights for sale?
Also, does anyone have the drum brakes for an english axle for sale?
Cheers, Chris
Mr Whippy
posted on 30/7/08 at 01:51 PM |
£10 for 2 the mushrooms send me a u2u with your address forget the postage. Their the MK ones, unused.
Macbeast
Mushroom inserts from Rally Design I think
posted on 30/7/08 at 01:57 PM |
MNR?
posted on 30/7/08 at 02:56 PM |
Re brakes unless you plan to Autotest the car go for discs it is now the cheaper option.
sprouts-car
posted on 30/7/08 at 03:09 PM |
Where sells a disc option for english axle?
posted on 30/7/08 at 04:58 PM |
Escort Mk3 240mm dia solid front discs (also used on early Sierras) -- dirt cheap
https://sslrelay.com/buypartsby.co.uk/brake-pads-newer.php?recordID=4673
I have link on another PC for brackets to take Sierra rear calipers.
[Edited on 30/7/08 by britishtrident]
sprouts-car
posted on 30/7/08 at 05:18 PM |
what about the calipers? I assume they also need to be cable operated for the handbrake. Also the bracket to hold the caliper?
Mole
posted on 30/7/08 at 07:20 PM |
posted on 30/7/08 at 11:34 PM |
short track 123 on here sells brackets to convert to disc. The disc centre will not fit over the half shaft hub without a bit of a tweak, the disc
centre is a bit too small so grind the outside off the rear hub. Some
here on ebay.
[Edited on 30/7/08 by Peteff]
