Benzine
posted on 4/8/08 at 12:32 PM |
Injection fuel pump location
I've just got my bosch fuel pump in the post. I've already got my low pressure pump connected from tank to swirl pot, I just need to fit
the high pressure pump now. Should this be close to the engine end of the car? or mounted in the back with the other pump.
spanks
trogdor
posted on 4/8/08 at 12:46 PM |
I don't think it really matters as long as it has a good feed from the swirl pot, ie not higher and with no kinks etc.
Man i wish i was at that stage!
mark chandler
posted on 4/8/08 at 01:20 PM |
Swirl pot is up front so sit it next to that.
Regards Mark
jimgiblett
Most manufacturers fit the pump near (or in) the tank. Howerver,this is more likely a maintenance reason than a performance one. eg. pumps dont like
runnining dry (pump failure in a short period of time) and a pump further from the tank will take longer to prime.
- Jim
[Edited on 4/8/08 by jimgiblett]
Benzine
posted on 4/8/08 at 01:23 PM |
no it isn't
Mix
posted on 4/8/08 at 04:12 PM |
Hi
Mounting it closer to the inlets reduces the length of high pressure fuel line available to spring a leak.
Regards Mick
matt_claydon
posted on 4/8/08 at 05:41 PM |
Injection pumps don't suck well so general advice is close to (and just below) swirl pot (or tank when you don't have one).
