Author: Subject: Megasquirt
whitestu
posted on 5/9/08 at 09:35 AM Reply With Quote
Megasquirt
I was thinking about converting to ITBs and saw these on the autotune website
Link
Inc shipping it comes to under $280 which is about £165, which seems really cheap.
What else would I need other than TBs, sensors, wiring harness and fuel pump / swirl pot etc?
Stu
[Edited on 5/9/08 by whitestu]
Paul TigerB6
posted on 5/9/08 at 09:48 AM Reply With Quote
A manifold??
whitestu
posted on 5/9/08 at 09:51 AM Reply With Quote
I've got one, or would make another to suit.
Anything else?
Stu
Benzine
posted on 5/9/08 at 09:58 AM Reply With Quote
Laptop, soldering iron, patience & persistence (for a wiring n00b like me, anyway)
whitestu
posted on 5/9/08 at 10:02 AM Reply With Quote
Wiring it in is no prob and for $280 the unit is fully assembed.
Stu
Benzine
posted on 5/9/08 at 10:33 AM Reply With Quote
you'll still need to solder in the sensors etc to the plug that then plugs into the megasquirt unit
Paul TigerB6
posted on 5/9/08 at 10:36 AM Reply With Quote
Stu
Dont forget that there is likely to be VAT, duty and handling charges to add to the above price.
Chippy
posted on 5/9/08 at 10:39 AM Reply With Quote
Don't forget that you will, (I did), have to pay import tax, plus delivery of £15 to PO as well, and that pushes the price "UP" a fair amount. Just my 2P worth. Ray
omega0684
posted on 5/9/08 at 11:37 AM Reply With Quote
you will also need all compatible sensor, water temp, air temp, tps, trigger wheel and vr sensor, map sensor, lambda sensor etc.
the innovate lambda sensor on there website looks cheap as well
piddy
posted on 5/9/08 at 12:01 PM Reply With Quote
Also the wiring harness unless you make your own.
big_wasa
posted on 5/9/08 at 05:36 PM Reply With Quote
I am planning on buying one. I have already already picked up some cheap Tb's.
martyn_16v
posted on 6/9/08 at 08:19 AM Reply With Quote
Time. You will need lots of time. Too many people buy them these days expecting it to be virtually plug and play, it's not. They're cheap not because they're poor quality compared to commercial units, but because you have to do a fair bit of learning to be able to do a decent install on your particular engine. It's worth it though, once you're up and running you'll have a much better understanding of what's going on, and you'll have a very feature rich and reliable system that'll hold it's own against stuff that cost 5 times a much
