Author: Subject: air box
iceman26
posted on 18/9/08 at 09:38 PM Reply With Quote
air box
i had my first run out tonight and have got flat spot at7k
i know i need to get it dyno set up
but i would also like a air box could someone recommend were i can get one from and also the dyno kit
thanks
forgot to say is fazer 1000 on carbs same as r1 carbed
thanks
posted on 19/9/08 at 08:04 AM Reply With Quote
The main problem is going to be that depending on your air box, exhaust system etc there isn't going to be one "kit". You might need to try lots of different jets and keep the one that works best.... Alternatively places like TTS will try the different needles and just sell you the one which gave the best performance.....
posted on 19/9/08 at 08:43 AM Reply With Quote
Aaaar.... land ashore me hearty and get down to the 'Builders Yard' at your nearest B&Q.
Cast an olde sea dog eye at all ye olde gutter /waste pipes and accessories (cutlasses, skull and cross-bone flags, etc).
They will have everything you will ned to make a decent airbox for your fine galleon... just takes a bit of thinking, cutting, gluing, pillaging, etc!
(Sorry... it is official talk like a pirate Friday today!).
locoboy
posted on 19/9/08 at 08:47 AM Reply With Quote
I think i still have my R1 carbed airbox in the garage.
Yours for £10 posted if you want it.
Locoboy
Jubal
posted on 19/9/08 at 09:34 AM Reply With Quote
Just a voice of caution. My airbox was once connected to the carbs by drainpipe bends. It turns out they go brittle over time and when a stone smashed mine it chucked bits of plastic into the carbs.
Oh, and ooooarrrrrrrr!
posted on 19/9/08 at 10:41 AM Reply With Quote
Aa-haar... locate some expoxy resin (my new best friend) from Davy Jones's Locker and give it a coating.
Makes the galleon much stronger and less likely to be damaged by the reef!
