Author: Subject: top ball joint covers for SVA
jabbahutt
posted on 6/10/08 at 02:12 PM Reply With Quote
Afternoon all
Struggling to find some of these for SVA. I've tried ebay and Tifosi and come up empty handed. I've seen photos on here of boots that cover the main part of the ball joint and that's the bit I'm having fun covering as anything cable tied slips off because of the awkward shape.
Any ideas people?
Many thanks
Nigel
posted on 6/10/08 at 02:33 PM Reply With Quote
I cut up an old inner tube into strips. with a 2nd pair of hands we stretched some strips around the outer circuference of the ball joint nice and tight so it sort of closed over the edges. Holding this in place over the threaded section and nut I then stretched some more strips around the threaded section and nut over the ends of the first strips. This was then cable tied in place to hold everything together.
Possibly a little difficult to explain without a pic though...!
It certainly wasn't an "elegant" solution, but the SVA man was satisfied with it's "permanency". Although it did "fall-off" on the way back home
ETA...
Found some piccies to help - you can see where I used the same technique on the base of the headlamps too
ball joint cover 2
ball joint cover 2
ball joint cover 1
ball joint cover 1
[Edited on 6/10/08 by nick205]
jabbahutt
posted on 6/10/08 at 02:58 PM Reply With Quote
Cheers Nick
Much appreciated, I've have a go tonight.
JAG
posted on 6/10/08 at 02:59 PM Reply With Quote
I covered this area with electrical 'split' conduit.
It was held on with two cable ties as per the pictures above.
Justin
Paul TigerB6
posted on 6/10/08 at 03:24 PM Reply With Quote
I'll dig out the pair that i have if you like Nigel. Brand new and never fitted - you are welcome to borrow them for SVA. Its not like i'll be needing them for quite a while!!
paulf
posted on 6/10/08 at 03:31 PM Reply With Quote
I put a length of fuel pipe over the nut and secured it with a cable tie.If you cut the pipe carefully it is possible to have the ends almost butted together and then tuck the cable tie in between so it hardly shows.The SVA tester was happy with it and they are still on my car as they look neater than rusty lock nuts.
Paul.
John22000
posted on 6/10/08 at 04:48 PM Reply With Quote
Same solution here as well Nigel, bit of old innertube and cableties exactly the same as the photo.
I managed to get some U-Trim around the end of the headlamp bar and this was acceptable.
One problem I had and this will depend on your headlights, is the mounting bolts. (Where the cables go in). Mine were still contactable despite being recessed and having the edge trim on the headlamp bar. I managed to get around this with a bit of careful trimming of some nut covers.......just one to bear in mind.
John
Stuart_B
posted on 7/10/08 at 09:43 AM Reply With Quote
hi,sorry for teh hijack, but what do you do with the ends of the cable ties?
thanks
stuart
posted on 8/10/08 at 10:13 AM Reply With Quote
thanks
stuart
Cut them flush and make sure they're pointing down or backwards where the SVA testers sphere can't or doesn't come into effect.
