Author: Subject: running ESC ignition and bike carbs
will121
posted on 12/10/08 at 06:00 PM Reply With Quote
ive had a busy day making up zetec manifold for my ZX9 carbs (bit rough but works), thinking of trying to run the ignition on a Escort ESC ignition module firstly rather then megajolt, does the ESC map run a safe map for a 130bhp 2litre zetec? or should i just got for the TPS megajolt?
[Edited on 12/10/08 by will121]
big_wasa
posted on 12/10/08 at 06:11 PM Reply With Quote
You need to run a vacume conection to the Esc for it to alter the advance/retard of the ignition. So it is better suited to a single carb.
Ive run a zetec on the esc, but it's not perfect The advance curve is set for an 8v engine.
That said one of the guys on here ran one for quit a bit on his zetec escort.
Buy the Mjl to start with imho
[Edited on 12/10/08 by big_wasa]
posted on 12/10/08 at 06:32 PM Reply With Quote
If you have the ESC I would give it a go but I'd defo recommend a Megajolt.
However I've found mine starts and runs pretty good with no ECu at all, just getting the 10 degrees from the EDIS! Not driven it like that mind
Mal
posted on 12/10/08 at 07:30 PM Reply With Quote
Yes, I got my car through the SVA test and drove it for a while with just an EDIS until I fitted a Megajolt.
