Steve Lovelock
posted on 14/10/08 at 07:58 PM |
Dead LC1 - Where are the cost effective replacements from?
I need to buy a LC1 sensor which I believe is the Bosch LSU4.2 (#3737).
I can only find them for about £70 in the UK but can get them for £40 in USA. Is there anywhere cheaper in the UK?
meany
posted on 14/10/08 at 08:16 PM |
did you try :
http://www.gendan.co.uk/
the_fbi
posted on 14/10/08 at 09:28 PM |
eBay is your friend.
£35 + Delivery, UK supply although you may have to remove the connector and put on your old one. I can't remember what the standard on with the
LC-1 is like.
Steve Lovelock
posted on 15/10/08 at 06:21 AM |
Well the £35 sensor comes with only 5 wires and the current one has 6 or 7. Will a numpty (ie me) be able to work out which wires to join together or
can I assume that the colours will match?
posted on 15/10/08 at 07:51 AM |
Just to confuse, the connector has 6 wires in and 5 out!
There's an internal calibration resistor in the sensor plug - which shouldn't be removed.
