Author: Subject: First MOT pass!
Shilvers
posted on 30/10/08 at 04:58 PM Reply With Quote
First MOT pass!
Well, it did technically fail on the offside headlight aim being too high & the front plate being the wrong size but I'm well chuffed with the result!
New plate sorted as below:
Needless to say, I've now removed it!
posted on 30/10/08 at 05:10 PM Reply With Quote
Is that a smaller lower numberplate below the nosecone?
Can you pass the MOT if you have two plates (one correct and one incorrect)??
I'm worried they might query my stick-on plate @ MOT and obviously whereas putting a temp correct plate on is easy, temporarily removing a stick-on plate isn't!!!
posted on 30/10/08 at 05:19 PM Reply With Quote
locost solution would be to cover the stick on with insulation tape!
Shilvers
That is the smaller plate below. He didn't seem to mind as long as there was one legal one there, and he knew the proper sized plate was coming off as soon as I got home. I just cable tied it to the grill. If your worried just mask your smaller plate over so it doesn't show. They can't argue with that even though they know very well what it is.
Shilvers
Beaten too it!
posted on 30/10/08 at 05:29 PM Reply With Quote
Aha! duck tape saves the day as ever.....
I recently broke the magic circle code of conduct and revealed the holy laws of DIY to my wife
1) if it should be stuck and isn't- duck tape
2) if it sticks and shouldn't be stuck- WD40
anything else is just showing off
Cheffy
posted on 30/10/08 at 09:19 PM Reply With Quote
But I have had a couple glasses of wine!
Mart.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
scutter
posted on 30/10/08 at 09:32 PM Reply With Quote
Duck tape is like the Force, it has a light side a dark side and holds the universe together.
ATB Dan.
