Krismc
| posted on 2/11/08 at 11:50 AM |
Megasquirt- Not communicating
i no some people have had bother with comms between laptop and ms, i cant get mine to connect either can some one help me out??
Ive got a old laptop with serial- serial with windows Me that wont connect.
Ive got a borrowed laptop with serial to USB with windows xp- although laptop doesnt seem to like the usb/serial convertor.
So i finally got my new laptop today and installed everything and it wont connect still- its running VISTA(i know this may cause a few problems- but i
should still be able to connect)
I fear i may have a broken ECU because it would connect last week but we found that the wrong firmware was on the ms it should be .29
And i had a clutch problem, so i removed the engine repaired clutch and put back together no when i used to put my key in and turn to ignition the
fuel pump would prime and then cut off- it now doesnt??
On checking the wiring(i havent got a diagram) i see then ms controls the earth to the fuel pump via a relay- if a add a earth the fuel pump runns
continuosly.
Can anyone tell me how to test to see if im getting a proper connection.
[Edited on 2/11/08 by Krismc]
rayward
| posted on 2/11/08 at 12:50 PM |
if you'r really stuck, and wanted to post your unit to me, i can test/possibly repair it for you?
Ray
| posted on 2/11/08 at 01:03 PM |
Does the ECU itself have a decent earth?
omega 24 v6
| posted on 2/11/08 at 01:57 PM |
Power at the squirt?? first port of call Remember it WILL NOT communicte unless the squirt is powered up. Also in communications check tour settings
first.
piddy
| posted on 2/11/08 at 03:25 PM |
Have you checked your relays?
Check you have power at Fuel pump and main relay.
See diagram.
Krismc
| posted on 2/11/08 at 04:40 PM |
quote: if you'r really stuck, and wanted to post your unit to me, i can test/possibly repair it for you?
Ray
Yea im not entirely sure its the ecu yet, not sure how to test?
quote: does it have a decent earth
seems to be fine, they are alll into one plug unless the plug is gone- where can i test earth inside ecu??
See diagram.
yes both relays are ok, the earth isnt there at pump relay but i belive its controlled via ecu pin 37??
first.
Do you know what pin powers up ECU???
omega 24 v6
| posted on 2/11/08 at 08:04 PM |
Yep pin 28 as per Piddy's above diagram.
Krismc
| posted on 3/11/08 at 05:23 PM |
Right so as per diagram, if ive got positive and negitive on them point, chances are the ecu is fecked?
also i dont know if this is a issue but there is a very low whine on my speedo. ive went through all my wiring and every thing on whole car seems
fine.
