Does anyone know of a 'cheaper' source for some honda cogs to put in my 954 blade box? Need 4th and 5th me thinks!
try andy at ab performance
. . . or Dave Silver Spares. They do both genuine Honda parts and OEM.
yea andy is your best bet he takes all my 954 gear
his no is 01449736633
cheers malc
i got mine (893 blade) from www.lings.com
Dead easy to order if you've got the part numbers.
Be surprised if you can get pattern parts, there's just too many subtle variations between the models to make manufacture viable for anyone.
Charlie
give me a call on 01449 736633 - I know you havent had the car long since the previous owner had the box done here.
If you want to bring the motor here I will do the gears at cost and fit them F.O.C for you.
regards
AB Performance
Originally posted by Andy B
Charlie
regards
AB Performance
Hi Andy, thanks for that I'll give you a shout on monday. I've got the cases split and shafts out so only need to send them to you if thats ok?
Managed to get this finished this weekend, cost £222 quid and did the work myself... Just got to get it back in and weld up and engine mount!
Thanks for the offer andy... with it all in pieces it made sense to do it here rather than send you 50 odd parts!
Took about 10 hours to get apart and rebuild. Not bad for a first timer i think!
Charlie
congrats..were did you end up getting the parts from might be usefull for the guys to know
Tony
Actually ended up getting them from V+J Honda in Bridgwater. Considered using AB Perf. But they got everything in next day for me ready to go!
By the time id got andy to get them, then get them down to me it would have been the other side of christmas!
Just waiting for a mate to pop round with a welder to sort a few extra car bits out so i can drop her back in!
