Can anyone please explain how they actually work?
As the caterhams use then, I trust they DO work, but how?
I can understand that the body roll is reduced when the inner wheel is lifted by the ARB during cornering, but why does this make my car go faster?
Is the reduction of front end grip just "reduced" to the same level as the rear end grip, if so, why is this good?
Is it making the car more balanced and easier to "feel" remaing level of grip before loosening it, or is weight somehow tranfered to the
rear improving rear grip?
My car is a simple book car with std Escort rear axle and 1600 X-flow, built from scratch, but I´m thinking of adapting a Caterham ARB.
/Hasse
rather than me typing stuff about this...here's a linky that explains about it good enough
Well it made me 2 secs a lap quicker in a back to back tests at Anglesey.
Front bar stiffens the front suspension, thus at the limit the rear (being more pliant) remains in full contact longer than the front thus generating
understeer. So in effect front anti roll bar helps balance rear oversteer with some front understeer giving you a balanced car.
Ideal is to have a perfectly balanced chassis without them but they are often used to reduce roll (hence the name) and can tune out under and over
steer as above.
The other problem with an ARB is that they spring you back out of a lean a bit too fast. In an emergency lane change manoeuvre they can promote roll
over on the second bend.
I had a saxo years ago and in tight left - right or right - left corners, there was a moment where it all went light before settling into the second
curve. You were never sure quite what would happen in that moment but once it settled, it was fine for the rest of the corner.
It does exactly what it says on the tin.
IE prevents rolling (when the suspension on one wishbone moves up but the other side moves down) whilst not preventing "normal" suspension
bump absorption (where one suspension doesn't move that much). If you had crazily stiff suspension you'ld get no rolling round corners but
you also wouldn't have much in the way of suspension of damping.
Hi
The front roll bar also allows you to run softer front springs to aid ride quality whilst still being able to control the body roll. This keeps the
suspension geometry in it's working area maintaining the front end grip. If no bar is fitted and excessive roll is taking place the geometry will
not be in it's ideal working area.
Cheers Matt
Originally posted by smart51
The other problem with an ARB is that they spring you back out of a lean a bit too fast. In an emergency lane change manoeuvre they can promote roll over on the second bend.
I had a saxo years ago and in tight left - right or right - left corners, there was a moment where it all went light before settling into the second curve. You were never sure quite what would happen in that moment but once it settled, it was fine for the rest of the corner.
That's far more likely to be down to knackered rear beam mountings on Saxo, or worn out/incorrectly matched dampers.
once had the front bar link arm snap on a cavalier (due to rust) when exiting a slip lane on to a dual carageway, did a full 360 right down the middle of the road, woke me up thats for sure replaced both of them after that
Originally posted by procomp
Hi
The front roll bar also allows you to run softer front springs to aid ride quality whilst still being able to control the body roll. This keeps the suspension geometry in it's working area maintaining the front end grip. If no bar is fitted and excessive roll is taking place the geometry will not be in it's ideal working area.
Cheers Matt
Originally posted by Hasse
snip
/Hasse
is a westy or caterham heavier than a book car then?
It seems that most car builders have gone for the softer spring, stiffer roll bar idea now. Probably more for comfort than performance, but even
sporty cars seem to do this as well.
Long story short, as always it comes down to keeping the tires in contact with the road as much as possible. If the car in leaning in corners, you
are probably losing the negative camber in the outside tires. So you need to either stiffen the coilovers which may make the tires lose contact with
the road more often on bumps, or fit an ARB. The only drawbacks to ARBs are weight and stiffer wheelrate on single wheel bump (when only one wheel
goes up the ARB has to twist).
This is basically how the ARB works. When the outside wheel goes up due to roll, the bar trys to stop it because the inside wheel is trying to do
down. Result is higher roll resistance and less roll.
Cheers.
i am in the process of making a stiffer bar for the front of mine, what is the best indication of the bar now being too stiff?
Thanks for all replies!
/Hasse
