Hi All,
Im about to put bushes in to the wishbones do i need to use grease, if i do what type? and where do i apply? between bush and wishbone or between
crush tube and bush or both. Cheers.
Use some moly grease between crush tube & bush.
Used Rubber grease on mine , lot less messy than moly grease .
Silicone Rubber Grease from Radio Spares on mine.
You can use any grease that you happen to have, Poly bushes are not affected by oil or grease. Gave mine a good lathering in the stuff, makes it easier to get them together, then washed of the excess with parrafin. Ray
