I'm planning a car with the handbrake on the front wheels, so a traditional handbrake lever seems wrong. What cars had a handbrake lever in the
dash?
Are dash handbrake levers SVAable?
2CV/Dyane had umbrella handle just under the dash
the indestructable toyota hi-lux.
thats the only one i know of.
rob
2cv, old isuzu troopers, ford ranger
My grandfather had the coolest car in the world or at least we thought so as kids...knobs n buttons everywhere weird sticky out indicators you had to flick a switch left or right to operate,even a push button to start it...handbrake was next to the steering wheel...Wolsley 444! cooler than owt that was.
mercs
VDubbleu bay window camper
They were grey plastic rectangles with a trigger.
Dave
My old Toyota Hi-Ace pickup had one in the 80's
God I feel old now
cortina shaped p100
P5 rover
Don't some Cateringvans have a dash handbrake?
Ford Corsair (if you can find one)
If you wanted front calipers with a handbrake setup try Xantia's!
Early XJ6
Renault 4
Lotus Elan! I just happen to have one of these handbrake levers I was going to use it on my build but ended up using a Range Rover one instead. U2U me
if you want it.
If you stick it in the "safe area" around the sterering wheel it should not cause SVA problems.
Caber
Series I II & III XJ jags, umbrella type.
Citroen BX
FWIW,
The mighty GT40 also had the handbrake under the dash....
Nissan pick up, we have one at work but damned if I know what model. It's not too old though.
Regards Kipper.
My twin cam Lotus Europa back in the 70's used to have one.
Series 2 lotus 7 had one
Originally posted by caber
Lotus Elan! I just happen to have one of these handbrake levers I was going to use it on my build but ended up using a Range Rover one instead. U2U me if you want it.
Caber![]()
Dax rush uses it so it must be SVA'able
