DAMAGED but cheap Sparco Formula Helmet. Size Small (56cm).
This helmet was dropped a while ago and as a result was no longer suitable to race with. However, it would be ideal for an open-topped car where the
driver needed protection from the wind and insects. Other than the small crack on the left hand side, the helmet is in good condition. The visor is OK
and could do with a clean. If you're really picky you may want to change this or fit a sexy mirrored one! It's a non-HANS helmet.
CLICK HERE FOR MORE DETAILS
£75 posted
It's this one
Safety Devices EXPIRED 6 point Harness.
Previously used for racing until it went out of date. Still functions well.
Comes with 2 NEW top plate and 4 NEW normal mounts for harness clips (worth about £15 on their own)
£65 posted (or £55 without the mounts)
