Kent Cams BCF3 camshaft I think this is the biggest lift/duration you can get without having to machine the cylinder head. Hasn't been
used that much. There is a light water mark on the end journal (the non-drive end) but it only covers 1/3 of the width and would probably polish out.
£20 collected (can post at cost)
AE Oil pump Been used, but not for long. Kept as a spare for racing. £10 collected (can post at cost)
1300cc oil pick-ups (3 of) - £5 each collected
Timing cover (731M6059AA) includes new oil seal - £8 collected
1300cc sump - good condition with sump plug, gasket face flat £20 collected
Radiator - Brand new , but with storage marks. This was kept as a spare that I never got round to using. Has a screw cap and overflow and
modified inlet/outlet pipes (90 degrees off) £20 collected
Axle case - usable with a little work - £10 collected
Coilover springs , all 8" long and 1.9" inner diameter
2x300lb - £10
2x180lb - £10 per pair
3x400lb (yes 3, but 3 for the price of 2) - £10
2004 MOMO Nomex race suit. Size Medium (54) I'm 5'9" and a 40" chest and fitted me fine at both 11 and 13 stone , but would
fit taller/shorter and fatter/thinner. Overall very good condition with a couple of minor issues (see below and pics). The elasticated sleeves are
still stretchy and it has always been stored out of sunlight so it hasn't faded. PM me for pics, I can't seem to get these ones to work!
Meets current Blue Book requirement for a race suit (Standard 8856 2000).
There is a little wear to the stitching over the right hand pocket (caused by harness straps). There is also a small patch on the seat (approx 2"
by 1" ) where there was a small tear. I had the suit patched by a seamstress in the same nomex material in the same colour with the same
stitching so it barely shows.
£115.
Yellow genuine Westfield pre-litigation bonnet
Dimensions:
Length 99cm
Width at rear: 96.5cm
Drop at rear: 18cm
Width at front: 70cm
Drop at front: 16.5cm
Overall good condition, but with some minor damage, most notably at the front corners. Paint in good condition. £30.
Fire Extinguisher and mounting bracket
Will need to be re-filled. Or, can be used as a weapon next time you get cut up by a muppet in a Volvo. The gauge appears to show it holds pressure
well.
£make me an offer, but obviously not a massive one.
K&N Filter Care Service Kit - used once so nearly full. £3 collected
BRAND NEW set of +0.90 piston rings (R25106), never used but box is tatty. SOLD TO STEVE M
8x1300cc con rods. I haven't used them and they look OK. £1.50 each or £10 for all 8.
Vanderwall Con Rod std bearings (VP819), never used but box is tatty. SOLD TO STEVE M
DGAV 32/26 carb in poor condition but could be useful for spares or a rebuild project. Not all there! I also have some jets and other bits.
£10.
2xYokohama A509 13" tyres. Quite old but at least 5mm of tread and in good condition. £20 the pair or £3,500 each.
8" brake backing plates I have used these and they seem fine - £12
9" brake backing plates I haven't used these but they seem fine - £20
I also have loads of little parts, like valves, head bolts, push rods, gaskets etc that it's too difficult to list individually. If you're
after something I might have one.
[Edited on 28/7/13 by 82 Locost]
Right
Just been offered a job in Italy so this lot has to go. Offers?
Collection from either YO30 2AA (York-ish) or FY8 5DR (Lytham, Lancs).
PRICE DROPS ON WHAT'S LEFT.
Originally posted by 82 Locost
Kent Cams BCF3 camshaft I think this is the biggest lift/duration you can get without having to machine the cylinder head. Hasn't been used that much. There is a light water mark on the end journal (the non-drive end) but it only covers 1/3 of the width and would probably polish out. £10 collected (can post at cost)
AE Oil pump Been used, but not for long. Kept as a spare for racing. £5 collected (can post at cost)
1300cc oil pick-ups (3 of) - £3 each collected
Timing cover (731M6059AA) includes new oil seal - £5 collected
Radiator - Brand new , but with storage marks. This was kept as a spare that I never got round to using. Has a screw cap and overflow and modified inlet/outlet pipes (90 degrees off) £15 collected
Axle case - usable with a little work - £5 collected
2x300lb - £8
2x180lb - £8
3x400lb (yes 3, but 3 for the price of 2) £8
2004 MOMO Nomex race suit. Size Medium (54) I'm 5'9" and a 40" chest and fitted me fine at both 11 and 13 stone , but would fit taller/shorter and fatter/thinner. Overall very good condition with a couple of minor issues (see below and pics). The elasticated sleeves are still stretchy and it has always been stored out of sunlight so it hasn't faded. PM me for pics, I can't seem to get these ones to work!
There is a little wear to the stitching over the right hand pocket (caused by harness straps). There is also a small patch on the seat (approx 2" by 1" ) where there was a small tear. I had the suit patched by a seamstress in the same nomex material in the same colour with the same stitching so it barely shows.
£100
Dimensions:
Length 99cm
Drop at rear: 18cm
Will need to be re-filled. Or, can be used as a weapon next time you get cut up by a muppet in a Volvo. The gauge appears to show it holds pressure well.
8x1300cc con rods. I haven't used them and they look OK. £1 each or £5 for all 8.
DGAV 32/26 carb in poor condition but could be useful for spares or a rebuild project. Not all there! I also have some jets and other bits. £5
2xYokohama A509 13" tyres. Quite old but at least 5mm of tread and in good condition. £15 the pair or £3,500 each.
8" brake backing plates I have used these and they seem fine - £8
9" brake backing plates I haven't used these but they seem fine - £14
I also have loads of little parts, like valves, head bolts, push rods, gaskets etc that it's too difficult to list individually. If you're after something I might have one.
