just need to cut the end off a sealed pipe to finish my fuel system so would be greatful if I could borrow a rotary pipe cutter.
I would return it same day
If you can't find anyone to lend you one they aren't expensive to buy:
link
Craig
I've got one in Mansfield if you want to borrow it
Pete
Ravenshead ng159dp
I have a 15mm and 22mm pipe cutter + one for smaller pipes eg fuel and brake if you want to borrow it.
Paul
Ive got a 100mm one
Ive got a 100mm one![]()
Its a viento it will need a 4" size fuel pipe to make sure
hi guys,
let me measure the pipe and let you know.
thanks for getting back to me!
