Does anyone have much experience with these Zetec inlet manifolds and ECU's?
I'm going to be using a 1.8 zetec and can't afford throttle bodies and this seemed a good solution (although their advert doesn't
mention cost anywhere!)
Any advice for or against?
hi
i used the full system,
not too bad, ecu was easy to use, software was great!
would be cheaper to make a manifold buy so bike t/bodeis and do mega squirt
imho (if i was going that way again)
as you still need a throttle body and injectors etc from the engine
but the griffen system was ok !
hope that helps, i
I've got the throttle body and injectors all on the engine already, so no extra expense there.
The site doesn't mention how much the kit costs - can you remember how much it cost you?
sure it was about a grand ( £980 )
so not that cheap,
there are cheaper ways !
like i said before, mega squirt and t-bodies
[Edited on 19/3/08 by ch1ll1]
If the click on the catalogue on the front page of their website it takes you to a page where you can download pdf versions of the catalogue and a
price list - having had a look I'd be sitting down when you do it
WOW you're right £980!!
OK maybe i'll be giving that a miss!
They advertise it as the cheap solution, but I can't think of many ways much more expensive...
OK, thanks for your help guys
i have taken the 1.8 escort engine, and used the mondeo 2lt plastic manifold and stock ECU. This gives a very locost option, but still very drivable
and good mpg.
Its easy to do and id gladly help guide you through how its done.
The only expense i had was for the custom plenum connecting the throttle body and the MASS meter ( cause of bonnet space ) and the air filter!
