Hello
What order should I wire these up?
A - 12V Feed, Fan, Fan Switch, Earth
or
B - 12 V Feed, Fan Switch, Fan , Earth
B but both work the same
not another thing going to work today? your going to be well plastered at this rate...
[Edited on 13/11/08 by Mr Whippy]
Yup. It makes no difference whether you switch the +ve supply or the -ve supply..... Unless the fan body is earthed in which case you wouldn't want to switch the negative (you'ld have a constant +ve feed and an earthed fan body)....
New avatar for you once you have completed the wiring and celebrated with a few glassed of the Islay malt...
Mr Whippy, you have too much time on your hands!
since my schedules are a work of art and I'm
upto date
I am going with A) I had an amp meter hooked up and decided I didnt need a relay
Ford usually use "A" good enough for me. No relay used on my car, just a fuse.
