Chaps
Stoopid question, but am planning my dash layout, so need to be reasonably accurate.
Would like to know how gauges are measured: eg 80mm gauge does the 80 refer to the face diameter or the outer bezel diameter.
Told you it was stoopid.
Thanks for your help.
Simon
I would guess it refers to the size of the mounting hole, just to throw another possible spanner in the works.
dunno though. electrical components and things are measured like that but dash dials I donut know.
Think you're right. Just had a look at the FAQ pages of greegauges site. Therefore reckon bezel are + 5mm approx.
Will owrk of that I think
Simon
Have a look at Technical/FAQ note 11 here
http://www.etbinstruments.com/homepage.htm
Perfect
Cheers wicket
Simon
So Simon, how come you havn't been to one of our local meets, we don't bite
Next one is Sunday the 1st of Feb at Newlands Corner, nr Guildford
Jason
Just an extra. Greenguages do a 86mm size which is good if you fined the 80mm too small but dont have room for 100mm.
Jason,
Once car is built, I'll be there - aside of working in London and not getting home till 7pm, then going to work elsewhere for a couple of eves a
week and Sat morning. And having a couple of sprogs, and a wife that always wants things doing, any spare time I get, goes on the car. So once car
built, I should have time to socialise
So, (if all goes according to plan) see you around Easter
Simon
Just to add my tuppence worth.
The gauges I sell (Didgital and Analogue) actual hole in dash sizes are...
2 1/16 inch - 52 mm
2 5/8 inch - 66 mm
3 3/8 inch - 85 mm
4 3/8 inch - 110 mm
These are the standard sizes world wide.
Simon, no problem, was only saying as I have found it very uplifting and encouraging to see a group of finnished locosts every meet. Will be glad to
see and welcome you at any point in your build or drive !!
Good luck with the juggling act as well !!
Jason
