I have hella mix and match rear lights in a carbon effect surround.
Im assuming the indicator needs to be in the surround towards the edge of the car, with the tail light led ring around it.
Working inwards towards the car the next hole in the surround should be reflector on the outer and stop light on the inner.
Just checking im not going a bit mad!
cheers
You can put it anywhere you like on the rear wing, provided it complies with the angles of visibilty in accordance with the SVA/IVA manual.
Phil
We mounted ours like so;
Mix n Match LED's 1
Not necessarily.
You could have any combination of what you want there with the only stipulation that the indicator, reflector and the side light must be no more than
400mm from the outermost edge of the vehicle. Also bear in mind that the stop light must be at least 100mm away from the fog light as well ( edge to
edge).
ETA Hellfire where are your reflectors???
[Edited on 7/1/09 by omega 24 v6]
Rearrange the following words Hellfire
The traffic act road nicked you are mate been has infringed
Rearrange the following words Omega
Officer oops fell off sorry they must have.
Or just one flush mounted
Found em......
PS - The reflectors are the ones that aren't lit up.
Phil
Thanks for everybodys input, wanted to be sure before makinga cock up , cheers
john
these maybe helpful.
rear lighting placement SVA
front light placement SVA
