To try and solve some ignition problems i have embarked on wiring a complete plug and play Megajolt unit with EDIS, coil pack etc, literally a
complete ignition system that will totaly replace the Megajolt already in the car.
I know that the Megajolt needs a 7.5 Amp fuse but does the EDIS need one? if so what Amp? and does the Fiesta Coil pack need a fuse? if so what
Amps.
From the diagram attached where should the fuses go?
15A fuse to EDIS and coil pack.
5A (or even 3A) fuse to the MJ itself.
(as recommended on the Megajolt site)
