I have a new set of smiths telemetrix clocks to fit, I didn't fancy fitting magnets to the prop flange so i plan to drive the sensor from the
original cable drive.
It is a manta 1.8 gearbox and I have used the rear part of the speedo and replaced the cogs with a round plastic disk that will hold the magnet.
Question is do you think I need one magnet or two. And what problems do you see in calibrating with this set up.
thanks Graham
speedo drive
Very much depends how many pulses the dial wants. The Racetech one I've used required ridiculous amounts of pulses so I ended up having about 32 pulses per wheel revolution (any less and it wouldn't work).... I would have though you'ld need minimum 2 but ultimately it's a case of trying and seeing!!! Are you using the standard sensor with your magnet / speedo combo? Some speedos are very choosy re sensors as well!!!
Hello. I fear you have over complicated this a bit too much. You do not use magnets with this type of sender as it is a field effect sensor. This type
picks up on bolt heads and needs four pulses per revolution. The pulses can be checked by powering the unit up without connecting it to a gauge (brown
12V+ and blue 0v) as every time the unit pulses the built in LED on the back will light up. You can just pick up on the bolt heads on the prop shaft
quite easily without modifying it at all. The end of the sensor needs to be within 2mm of the bolt heads to work.
I hope this helps
Dave
Originally posted by hicost blade
Hello. I fear you have over complicated this a bit too much. You do not use magnets with this type of sender as it is a field effect sensor. This type picks up on bolt heads and needs four pulses per revolution. The pulses can be checked by powering the unit up without connecting it to a gauge (brown 12V+ and blue 0v) as every time the unit pulses the built in LED on the back will light up. You can just pick up on the bolt heads on the prop shaft quite easily without modifying it at all. The end of the sensor needs to be within 2mm of the bolt heads to work.
I hope this helps
Dave
