reversing light?
blakep82 - 3/6/09 at 07:52 PM
i've got one of these
http://www.s-v-c.co.uk/prod/LED-plate-light.html
its e-marked, on'y about an inch long, 3 leds in it, is there any reason i can't use one as a reversing light?
matt_claydon - 3/6/09 at 08:50 PM
e-marking is irrelevant - it's e-marked as a number plate lamp, not a reverse lamp.
However, IVA (nor SVA) has any requirement for e-marking, all you need to do is comply with the following:
Reverse lamps;
1.
They must be operational
2.
The correct number must be fitted to the vehicle (Table 1)
3.
They must emit white light.
4.
They must be positioned to face the rear
5.
They must operate by selection of reverse gear, or be fitted with a telltale warning device.
6.
Where two lamps are fitted they must be fitted symmetrically and be a matched pair.
blakep82 - 3/6/09 at 08:54 PM
i'd searched through the IVA and hoped i wasn't missing anything.
so nothing about minimum or maximum sizes which is good.
as for emarking, its only e-marked as a lamp surely? i wouldn't think its e-marked specifically as a number plate lamp? i wouldn't say its particularly good as a number plate lamp lol i tried it and it was rubbish
matt_claydon - 4/6/09 at 06:54 AM
No, there are diferent Regulations for every lamp type specifying different colour, luminous intensity, beam angle etc. Part of the e-number on the lens tells you which Regulation is was approved to.
coozer - 4/6/09 at 07:34 AM
Does IVA say they MUST be fitted??
blakep82 - 4/6/09 at 11:43 AM
they sure do. minimum number of 1 lamp. and mandatory.
here's the only requirements
Reverse lamps;
1.
2.
3.
4.
5.
6.
no mention of needing to be e-marked though. mine emits white light, will face the rear, and will work off the gearbox. so looking good i think
