I've tried searching and found a few descriptions of wiring for the fog light but just wondered if anyone had a diagram - I work much better with
pictures
I'm kind of stuck with the IVA wording, as I understand I will need to be able to switch fog on and off with either low or high beam (or
both?).
I was just going to take a fed off the low beam but figured it won't work on main beam then?
12v supply - fog light switch - fog light - earth point
job done,
the fog light circuit runs independantly to the dipped / main bean circuit, so its operational with dipped and main beam on
The IVA manual states:
"The lamps must only illuminate when dipped beam, main beam or front fog lamps are lit"
So the above wouldn't work would it??
What if I take the feed off the feed to rear lamps > switch > fog lamp > earth??
This came up on rhocar forum a few days ago. Options were to use terminal 56 (if using the later sierra switches) on either switch to earth a switching relay to supply the fogs. Or take feeds to the fog light switch direct from the main and dip circuits through a suitable diode.
Another possible if using the late sierra switches would be to take a feed from a rear light supply direct to the fog and then run it's earth back to the fog light switch on the dash and on to terminal 56. This is only earthed when headlights are on.
Not in my experience.
Most tintops foglights operate with sidelights also!
Took feed from rear side lights to fog to switch to terminal 56. The fog light comes on with dip and main and not on sides. Good you say except when lights switched off the fof lights is out but it trips the relay that turns on the front lights, WTF????? Help
