Anyone have any idea what the peak and average current consumption of a pair of coils in wasted spark configuration will draw?
James
[Edited on 24/6/09 by cloudy]
Got a clamp meter? Every installation will be different i would imagine. Dependant on Cable lengths, Cable Cross Sectional Area, Material, Efficiency, Temperature etc etc. Plus any additional factors in the system. ?
Plug top coils or not?
I would expect the draw to be somewhere between 5-8amps peak. Most coils usually run off a 10amp fuse with no problems.
Seperate coils, but flak is right the fuse gives a good idea...
James
or like i said, an ammeter on the coil feed.
