Guy at work owns one of above, went to it this morning to go home, dead as wacko. lights work but rest of system dead. AA fella just shrugged his
shoulders and said you need an autoelectrician.
any ideas please
tony
Ring AA back and complain if the guy didnt even check the obvious fuseboxes and earths, or get a multimeter out
ECU fuse?
Edit.
If i remember correct, there is a comon fault with the citroen ignition switch.
All the curent for the car runs through the ign switch and it burns out.
Its years since I did one for some one.
There is a mod on the net to sort it if you do a search.
I may be leading you up the wrong path as I think that was somthing todo with the heater aswell.
[Edited on 27/6/09 by big_wasa]
